the whole ATC process in ladder is enormously huge pages and pages of drama. At what point machine stops?
Physically the tool change completes. It changes tools, puts the other tool back in the correct mag pocket, goes to the correct b axis position, the mill spindle oriented, etc....... what does not happen is the current tool does not update on the display and the cycle start stays illuminated. If you hit reset the mag moves. Shifter, etc... however I found hit estop then reset everything will stay in the correct position and i can enter the correct tool in the tool popup display. Like it is waiting on a finish signal.
Spindle orientation is done, Second home position is made. Magazine rotates to prepare selected tool?
what about parameters R78 , R44 and R48, R47, these are related to ATC.
R44 = - 400
R47 = 0
R48 = - 31720
R78 = 01000000
I will doublecheck them later today but had a picture on my phone of all the parameter pages.
is it possible to move ATC arm in maintenance mode?
