need help locating o-ring s for qt200
mthomure
Cast Iron
Feb 3, 2007
Joplin, MO
I am looking for the O-rings for a 1999 Mazak qt200 for the actuator.
The actuator is a Logansport Matsumoto ZKP150/52-22-01m.
I am trying to find what size the O-rings are so I can source them someplace besides the OEM. They want $375.00 for 10 O-rings.
Any help is appreciated.
Michael
With Mazak being Japanese they're probably JIS O-rings. If they're mostly small just buy a JIS kit. If not go to Maryland Metrics or The O-Ring Store. The O-Ring store sells smaller quantities though MM may have more sizes. Can't recall. Many times even buying a minimum quantity is cheaper then buying OEM.
Thanks guys.
The guy that helped me take it apart suggested taking them to Hyspeco which is 3 blocks away. They have a cone for sizing.
It cost $10.27 instead of the $375.00 from the OEM.
Again thank you for the help.
Michael
