HELP with SQT 30M with MAZATROL T32-3 connection
camiloorduz
May 21, 2020
Hi mates, I've been trying to connect the SQT 30M with mazatrol T32-3 from computer (9pin)to the CNC(25 pin) without success, I've found two different wiring connections and I don't know which one is the correct one. Can you guys show me how is your wiring connection? THANKS in advance:
this is the first option I saw:
And here's the second option I saw:
Thankyou
For T32 it should work with the first one, it requires RTS/CTS signals.
But do you have a software that can handle mazatrol protocol?
For EIA/ISO programs any terminal software will work but for mazatrol software you need special software.
I recommend MazWiew if you only requires to save and view (no edit) programs on your PC.
