How to Calculate pitch when tornado milling pockets with mazatrol
Likes Likes:  0
Results 1 to 3 of 3
    Mar 2011
    Wilmington, delaware
    118
    17
    22
    Default How to Calculate pitch when tornado milling pockets with mazatrol
    Hello,
    Iím new to mazak and donít have any real experience. So any constructive criticism is appreciated.
    Iím using a mazak pallet tech system with a nexus controller.
    The idea is to spiral cut an internal pocket.
    I need to calculate the pitch. Itís explained to me as the corkscrew action of the mill as it spirals down cutting the round pocket or socket.
    How do I get numbers that make sense?
    I didnít add material or sizes because Iím trying to find out how to calculate the number.
    Jun 2013
    Oregon
    1,553
    549
    930
    The pitch is the distance traveled in Z in one complete rotation. That value is whatever will give you the desired result.
    Jan 2013
    Plainfield, Indiana, USA
    1,745
    1328
    928
    Using a downward path of 5 degrees would be figured by:
    P=0.137*(D-d) where D is the diameter of the hole and d is the diameter of the end mill. If this is too aggressive then use a smaller constant. A few trials with a scrap piece of material should yield a constant that works for your situation.
