How easy is Mazatrol?
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Aug 2017
    Minnesota
    Default How easy is Mazatrol?
    My company just ordered three Mazak VCN 530c mills. They have the Smooth G control. We do all of our programming on the shop floor and we have Haas and Fanuc controls on our other machines. I have no experience with Mazatrol but now I'm going to have to learn it. I know that the Mazak control also accepts G code, but I'd be nice to use conversational for speed and ease of use. Our parts aren't crazy complex but all use custom fixtures. So my question is how easy or hard is it to learn Mazatrol coming from primarily Haas conversational? I was hoping they'd get us some CAM software to go with the 300+k they just spent on machines but that remains to be seen I guess.
    Feb 2015
    SWEDEN
    660
    109
    306
    Never used any newer Mazatrol control then T2 & T3 (30 year old machines).
    But even these old mazatrol machines are very easy and flexible to use.
    You can see Mazatrol as a CAM software in it self.
  3. Likes MattiJ liked this post
    Oct 2005
    NORWAY
    956
    468
    203
    I have only used Mazatrol on a lathe but that is super easy. 6 hours of training from a guy that knew his stuff and I had all I needed. When I wonder about something after that it's usually easy to find in the manual. I think I have heard that the milling machines are a little more difficult, but others will probably know about that.
    Nov 2014
    Florida
    6,156
    2439
    3061
    Depending on how you used the Haas conversational, did you define the tools in the machine, or did you just "know" you were using a drill and running it at xxxrpm and feedrate? Mazatrol will need you to define the tools. That was probably the hardest part coming from programming almost exclusively in cam, IMO.
    Jun 2013
    Oregon
    1,752
    624
    1080
    You can import tool models, making for a much more exact simulation after program creation. That is just one of many cool things about the Smooth controls. The power of the Smooth controller makes Haas conversational look absolutely archaic. It takes a bit to get used to the touch screen, but once you use it for a while, anything else seem wrong. Do not expect to become proficient with it overnight. It is a feature filled controller with a lot of depth, but in my mind, a powerful tool when used correctly. If you really want a different system for programming, Esprit and Mazak have partnered and make some nice programming software. Really awesome program simulations for anti collision.
  7. Likes dodgin, Philabuster liked this post
  8. #6
    Dec 2008
    New York
    10,398
    2713
    Quote Originally Posted by jacktorrance287 View Post
    mazak has many thinks to help you. milling it selects roughing and finishing mills and you can select max doc and woc on rougher per pass and the amount finishier takes. you tell it material type it auto selects feeds and speeds. basically it auto selects most stuff which you can change slightly. the mazak i ran also had afc or automatic feed control. when drilling or milling and it senses load is high it auto reduces feed to 50% til load ok or does a feed hold if overload still there
    basically mazak has a lot of thinks to make programming go faster and running program go better. same with drilling and tapping holes. usually auto selections are ok or need only slight adjustment. tool comp is automatic. restarts are easy and more fool proof
    for moderately simple parts it is rare to take more than 10 to 30 minutes to program with most time just reading drawing coordinates and punching in at control. and time always needed to make you your parallels are the correct height and tools wont hit vise jaws and if you want to edit program usually only takes a few seconds to change something
  9. #7
    Jul 2010
    Rochester, NY USA
    2,288
    10
    552
    Many new machines come with operator training available. Check if they got free training.
    Bill
  10. Likes Bobw liked this post
  11. #8
    Mar 2017
    73
    8
    I program both Haas lathe and Mazatrol T+ lathe with live tooling.
    When I'm back on the Mazatrol its so nice and user friendly and 5 time faster than the Haas.
    After there both set up and running both are very fast meaning one is not slower than the other.
  12. #9
    Feb 2005
    9,586
    16156
    11635
    My 2 cents...
    Mazatrol on a lathe... Its beautiful... So easy, and fast....
    I will NEVER EVER g-code a lathe EVER again in my life.
    On a mill.. (newest I've dealt with is a T+), not so great.
    Its awesome for simple stuff. quicky profile and some fancy holes..
    More than that and its kind of clunky and a pain in the ass.
    Your company is dropping 300k plus on some new machines, plus what you already
    have on the floor, and you have no software? That doesn't even make sense.
    Conversational at the control, on the floor, is VERY powerful.. But when you
    get into funky stuff. MUCH MUCH easier to do it sitting at a desk. I've stood
    at a control with pages and pages of points and profiles... F'n sucks. Especially
    when you already had to draw that crap out to get all the points and profiles.
  13. Likes Gobo, Philabuster, cwtoyota, mmurray70 liked this post
  14. #10
    Mar 2015
    Michigan
    538
    130
    240
    Quote Originally Posted by Bobw View Post
    My 2 cents...
    I agree with Bob here. I have yet to fall in love with a conversational mill control. It can be okay for drilling a couple holes, or maybe circle milling a couple holes, but I always found that any sort of even moderately complex contouring would be done faster on CAM.
    That being said, I have some experience with Haas conversational and some experience with Mazak M+ controls, and if given a choice between the two it's a no brainer. Some of the stuff I was able to do on the Mazak with relative ease I can't imagine having tried to accomplish on the Haas. I think you guys will have an advantage going from programming conversational to programming a different brand of conversational. Should just be a matter of taking some time to get used to the new controller.
  15. #11
    Nov 2012
    Wisconsin
    2,309
    3803
    2856
    In my opinion....Mazatrol shines best when used on the floor for standard complexity parts. Not saying you can't do some pretty complex stuff, but the average guy can do the average part pretty quickly. I recommend getting some MAZAK training....yes it can be taught from one person to the next......but I think you get the most bang for your buck through MAZAK. If your parts are real easy....no special training would be needed.
    However....(unless things have changed) the Mazak manuals will be useless to someone without some working knowledge of Mazatrol. They were written in a language I heard described best as Japenglish. Some ideas just didn't get translated that well.
  16. Likes Bobw liked this post
  17. #12
    Jun 2013
    Oregon
    1,752
    624
    1080
    Quote Originally Posted by toolsteel View Post
    We recently purchased a Mazak Bartac I-100. We have some Mazaks over 25 years old. Believe me, the manuals have improved by lightyears. They seem to be written by an English speaker, rather than translated from Japanese.
    And with a new machine(s) Mazak credits you with a certain number of training credits. The guys we had come in for our Bartac training were truly shit-hot. Although the Smooth controller is pretty new, they really new what they were doing.
    BUT--forget about any 5 axis stuff with Mazatrol. That is where I would recommend Esprit.
  18. #13
    Oct 2005
    NORWAY
    956
    468
    203
    Quote Originally Posted by Gobo View Post
    I can't say I agree with you on the manuals being written by an english speaker (my manuals are for a Quick Turn Smart), but mostly they are ok.
  19. #14
    Aug 2017
    UNITED KINGDOM
    25
    6
    I recently bought a VCN530 with the Smooth G Control.
    I've used the Matrix and Matrix 2 control on my Lathes and I find the Smooth G control much easier. If the machine is new then the training will be included. Honestly if you are used to programming on the shop floor then I can't imagine that you will have a hard time with the Smooth G control. Only thing is once you get too used to the touch screen you will be bashing the screens on other maachines and wondering why its not working .
    My fave thing about the Smooth G is the fact that the work-piece is drawn as you program without having to access another screen to check what you are doing looks correct. Another feature that is good but I haven't yet used is that you can import 3D models and pull features from that. I know it works for STP files but not sure how many diff formats it works on.
  20. Likes Philabuster liked this post
  21. #15
    Feb 2008
    Orange County, CA
    279
    52
    75
    Quote Originally Posted by Panza View Post
    Speaking of Manuals: I am kinda old school, I prefer the printed manuals, the standard machines come with the CD's, kinda a lot of information to wade through to get where you want, the new Lathe I have on the list for next year is for the printed manuals an extra $300.00 bucks, which is the way I will go, but that's just me...Anyone else prefer the printed manuals ?
  22. Likes Kingbob, Gobo liked this post
  23. #16
    Dec 2009
    Louisiana
    512
    193
    296
    Quote Originally Posted by Steve's Hobby View Post
    I'm with you on that one. We are an exclusively Mazak shop and I have already decided that next machine we buy I will demand the printed manuals be thrown in for free or I will make sure or Mazak sales guy crosses paths in the shop with the Okuma or doosan rep. He'll cave
  24. Likes Gobo liked this post
  25. #17
    Oct 2005
    NORWAY
    956
    468
    203
    Mazak over here changed to PDF's for manuals but everyone wanted paper manuals so they changed back to paper again. I got both, in case I wear out my paper copy I can just print a new one.
  26. #18
    Oct 2016
    UNITED KINGDOM
    46
    5
    18
    Printed is better, can have them to hand, open on the page you need on the bench whilst at the control. Stick a postit note in pages you need to refer to regularly, etc.
    Plus its more satisfying to throw at the apprentice to read when he asks the same thing for the 3rd time that day.
  27. #19
    Aug 2017
    Minnesota
    It's been a few months, thanks for all the replies. Well the new mills have arrived and they're a sight to behold. They're in the building and will be getting setup by the Mazak rep early next week. They came with training so I'm defiantly going to be taking advantage of that. Still no word on CAM software. The company has seats for Solidworks/SolidCAM and Gibbs CAM so we're trying to push them to get us a seat for our area. How are those for Mazak, post wise? My only experience is with Fusion 360 on my own time and I love it.
    The plan is for starting out to get our old programs into the new machines so we can at least start running parts in them in the mean time. We're also bringing more work back in house now that we have the capability. So there's going to be some programming coming up. This is all new for the company as they've been behind the times for a long time now and it's all been very old school. The Fanuc control machines that the Mazak's replaced were all 20+ years old and worn out.
  28. Likes HDFanboy, Spinit liked this post
  29. #20
    Feb 2017
    AUSTRALIA
    44
    21
    20
    Good to hear the machines have arrived and are close to up and running. I have to say after spending the first 17 years of being a cnc machinist programming and running fanuc controlled mills and lathes then having 9 new mazak mills and lathes replace them having to learn mazaatrol was a absolute breeze and in all honesty I never want to touch iso again. The conversational programming on the mills makes jobs that I might not haven even attempted in iso so simple to do its shocking. When we bought the machines I had 3 days of training and after that I was good to go. After a week of running the machines it was like second nature like i've been running them for 17 years.
    All our programming is done by each operator on the shop floor and we have written well over 2000 programs since we had to go from all our all old mazak and fanuc lathes to the new machines and we have all been doing that without any problems or need for gcode programs at all. Everything we have needed to do has been done in mazatrol including a heap of twin spindle part swapping turning on the lathes and in the intergrex machines and everything is awesome with them. Im sure you won't have any issues picking up mazatrol once you have seen how simple they make programming.
    Also we did pick up the mazak software for offline programming but we haven't really used it since all our operators just write the programs on the machines. All the software really does is put the smooth g or smooth x control panel on your computers screen so your writing the program on your pc exactly like you would on the control itself.
