[EIAMACRO-1]
UnitName=ENGRAVE
MenuName= ENGRAVE XC
WNo.=10
Data1-1=T,TOOL #,TOOL #,0,0,0
Data1-2=H,OFFSET,TOOL OFFSET #,0,0,0
Data1-3=S,RPM,MILL SPINDLE RPM,0,0,0
Data1-4=D,SAFETY,Z AXIS CLEARANCE,0,0,0
Data2-1=E,XYFEED,XY AXIS FEED MM/MIN,0,0,0
Data2-2=F,ZFEED,Z AXIS FEED MM/MIN,0,0,0
Data2-3=B,DEPTH,DEPTH OF ENGRAVING,0,0,0
Data2-4=A,SCALE,SCALE/TEXT SIZE,0,0,0
Data3-1=C,C START,C AXIS START POSITION,0,0,0
Data3-2=X,X START,X AXIS START POSITION,0,0,0
Data3-3=Y,Y START,Y AXIS START POSITION,0,0,0
Data3-4=Z,Z START,Z AXIS START POSITION,0,0,0
Data4-1=U,SPACE V,VERTICAL TEXT SPACING,0,0,0
Data4-2=V,SPACE H,HORIZONTAL TEXT SPACING,0,0,0
Data4-3=W,SPACE A,SPACING FOR ARC TEXT,0,0,0
[EIAMACRO-2]
UnitName=ENGRAVE
MenuName=INPUT TEXT
WNo.=11
Data1-1=A,1,DATA 1,0,0,0
Data1-2=B,2,DATA 2,0,0,0
Data1-3=C,3,DATA 3, 0,0,0
Data1-4=I,4,DATA 4,0,0,0
Data2-1=J,5,DATA 5,0,0,0
Data2-2=K,6,DATA 6,0,0,0
Data2-3=D,7,DATA 7,0,0,0
Data2-4=E,8,DATA 8,0,0,0
Data3-1=F,9,DATA 9,0,0,0
Data3-2=H,11,DATA 10,0,0,0
Data3-3=M,13,DATA 11,0,0,0
Data3-4=Q,17,DATA 12,0,0,0
Data4-1=R,18,DATA 13,0,0,0
Data4-2=S,19,DATA 14,0,0,0
Data4-3=T,20,DATA 15,0,0,0
Data4-4=U,21,DATA 16,0,0,0
Data5-1=V,22,DATA 17,0,0,0
Data5-2=W,23,DATA 18,0,0,0
Data5-3=X,24,DATA 19,0,0,0
Data5-4=Y,25,DATA 20,0,0,0
Data6-1=Z,26,DATA 21,0,0,0
save this as EIAMACRO.txt and put it into the nrm*** whatever it is directory and if your machine is set to english put it in the eng folder. then set bit 3 of parameter 81 to on and restart machine. fucking easy as. save the first program as 11.eia and the second as 10.eia
when you go to program, when you push the right softkey a few times you will notice a couple of new options. set your text size, position etc through engrave xc and your text through input data. if you need more than 21 characters just insert another input data unit and it will continue where you left off.
