How to save programs to a pc via CMT from a QT15 T32B
Results 1 to 10 of 10
    Feb 2018
    UNITED KINGDOM
    257
    102
    75
    Default How to save programs to a pc via CMT from a QT15 T32B
    Hi all
    On my Hyundai QT15n with T32B controller I have filled the memory with only 17 programs!!!! They are not even that big so obviously the memory is tiny
    The lathe doesn’t have to DNC option so I need to remove/save the programs from the control to my laptop via the 25pin cmt port inside the little access panel on the side of the control, I assume I can use a male 25pin rs232 connector
    The problem is my laptop doesn’t have rs232 or 9 pin, it only has usb
    So does anybody know the cable configuration I need and how I need to pin it for use with a USB adapter
    As for software to put on the laptop I have emailed GRIFFOBROS as I’ve read there stuff is very good for transferring mazatrol programs.
    All help appreciated as I don’t want to have to keep deleting programs and then re writing them because the memory’s full
    Marc
    Feb 2018
    DENMARK
    212
    12
    149
    I use a moxa usb to serial adaptor. Works great and I use it on all my machines. They are cheap
    Sendt fra min EML-L29 med Tapatalk
    Feb 2018
    UNITED KINGDOM
    257
    102
    75
    I will pick one of them up,
    Does anyone know the pin configuration for making up a 25 pin serial lead?
    Marc
    Feb 2015
    SWEDEN
    660
    109
    303
    I use USR-N510, they are cheaper.
    Make sure you pick a adapter that handles rts/cts (request to send/clear to send).
    T2 and T3 does not use rts/cts but T32 does.
  5. Likes M K liked this post
    Apr 2013
    South Australia
    457
    122
    148
    I think you will find Griffo bros is expensive for what you want. Mazview is cheap and works a treat. If you want to edit and write away from the machine then you will need either Griffo or Mazacam. For just saving programs Mazview would be my choice as the program is saved as you see it on the screen so you can study it in your office and see where it has to be tweaked and then go to the machine and make the changes. At the end of the day it depends on what you need and your budget. Couple of hundred compared to thousands
  7. Likes M K liked this post
  8. #6
    Feb 2018
    UNITED KINGDOM
    257
    102
    75
    Thanks for the reply’s
    I don’t need to be able to write or edit offline etc
    All I need is to be able to save to my pc and re load from my pc just to keep the memory from filling up on the machine,
    I will google Mazview as that’s sounds better suited to me and as a 1 man business the cheaper the better right now
    Marc
  9. #7
    Oct 2013
    United Kingdom
    166
    31
    Quote Originally Posted by M K View Post
    Hi all
    Marc
    I use cnc-link, low cost & very reliable. Call Keith, he's based in Sheffield. (google cnc-link).
  10. Likes M K liked this post
  11. #8
    Feb 2018
    UNITED KINGDOM
    257
    102
    75
    Quote Originally Posted by gmc1724 View Post
    Hi
    Thanks for that, i spoke to Keith who was very nice and very helpful, he supplied the correct lead and the software i needed, remotely set it up for me and i can now download and upload from my laptop to the Mazatrol T32B control
    CNCLINK Software – CNC Data Storage made simple.
    Thanks for everybody's input in helping me sort this
    Marc
  12. #9
    Mar 2017
    72
    8
    Quote Originally Posted by sudsy55 View Post
    I to use MazView and use it to back up and store programs.
    You will need a USB to 9 pin adapter and you will need to make a serial wire (25 pin) that connects to the 9 pin wire to a standard USB.
    The wiring diagram is provided by MazView and where they recomend you to buy the USB to 9 pin adapter.
    I here there is another way to wire it to your USB laptop but this worked for me.
  13. Likes M K liked this post
  14. #10
    Jan 2003
    505
    100
    156
    Yes you need a USB-serial adapter. I use mazview and I mostly like it EXCEPT I hate their licence! Every time you install it on a computer it needs to be on the internet and connect to their network to verify the licence. So if they disappear in a couple years Im up shit creek with my machine and all my Mazatrol programs.
    This is a huge piss off for me. Small companies like this come and go all the time, I dont want my business to be affected if they do go. I bought their software, I should have been given a key that will work offline, even if they are no longer around.
    I would certainly consider other options then Mazview if buying again.
