Hi all
On my Hyundai QT15n with T32B controller I have filled the memory with only 17 programs!!!! They are not even that big so obviously the memory is tiny
The lathe doesn’t have to DNC option so I need to remove/save the programs from the control to my laptop via the 25pin cmt port inside the little access panel on the side of the control, I assume I can use a male 25pin rs232 connector
The problem is my laptop doesn’t have rs232 or 9 pin, it only has usb
So does anybody know the cable configuration I need and how I need to pin it for use with a USB adapter
As for software to put on the laptop I have emailed GRIFFOBROS as I’ve read there stuff is very good for transferring mazatrol programs.
All help appreciated as I don’t want to have to keep deleting programs and then re writing them because the memory’s full
Marc
Marc
