integrex 200SY air issue
Likes Likes:  0
Results 1 to 5 of 5
    Jan 2012
    Florida
    227
    279
    83
    Default integrex 200SY air issue
    I just got a integrex 200SY I been working on getting it set up.
    I have a 40 tool magazine and was attempting to load tools.
    I must have hit wrong button and now I have air escaping somewhere in machine.
    My Air compressor is marginal and after couple minutes I get "low air pressure" Alarm
    Any help appreciated it has a 640T controller
    Apr 2021
    SWEDEN
    25
    6
    A little more info would be helpful.
    When in milling mode (unclamped mill spindle) my machine will blow a lot of air in the milling head fore some reason. Try clamping the spindle and see if it goes silent.
    Jan 2012
    Florida
    227
    279
    83
    THANKS I will try
    Jul 2006
    Arizona
    4,731
    18887
    4580
    Quote Originally Posted by ernieflash View Post
    I would bet money it is the positive air purge on the spindle. This is normal and you are going to need a bigger air compressor.
    Apr 2021
    SWEDEN
    25
    6
    The air purge on and around the spindle (except through the spindle during toolchange) is almost non existent on my machine. I have the C6 spindle though, and KMZ might be different.
    But when in milling mode it blows ridiculous amount of air on the belts and an air-oil mist on the gear in the head. The 200SY Mk II does not have an integrated milling spindle and has gearing in the head instead of the whole motor.
    I have a 7.5 kW screw and it works quite hard to keep up with the air supply. Since I hate hearing the compressor work so much I have installed an adjustable valve on the supply of air to the belts and the gear. It was like a handheld airgun wide open. I refuse to have that amount of air blowing and the gears get well lubricated even when choked a bit.
    But even so, this machine is a big air consumer compared to anything I have experienced before and I could not get away with much less than the compressor I have now. So yeah, he probably need a bigger compressor.
