Integrex Fusion640MT Mill spindle not reversing or stopping in EIA
Results 1 to 6 of 6
    Feb 2020
    CANADA
    Alberta
    Default Integrex Fusion640MT Mill spindle not reversing or stopping in EIA
    My Integrex functions properly in Mazatrol. Tapping drilling whatever the spindle seems to function correctly. In EIA M14 and M15 hang the machine (Program stops, Need to reset) and Tappng cycle does not reverse, Does anyone know what could cause this one?
    Nov 2016
    POLAND
    26
    Wrong m codes?
    Sent from my D5803 using Tapatalk
  3. Likes Philabuster liked this post
    Jan 2013
    Plainfield, Indiana, USA
    1,749
    1337
    928
    Check M Code list for YOUR machine. Try M3 (or M4 for counter clockwise) and M8. M codes are not standardized from builder to builder even though some are almost common.
    Feb 2020
    CANADA
    Alberta
    I found the M code book in Japanese and it agrees.
    Actually its a Mill/Turn and the following codes below are from the MAZAK manual
    Lathe Spindle (C-axis) M3 forward, M4 reverse, M5 stop.
    Milling Spindle M13 forward, M14 Reverse, M15 stop.
    Manual controls and conversational both work fine. G-code is the only method not working.
    These still don't work but I found other M codes that might work M203,m204 and M205.
    Nope those don't work either. Program in MDI just sits there.
    Feb 2020
    Michigan
    Following. Our mills do the same thing. They're all just vm's but in EIA programs, the spindle just floats to a stop after the M05. I've tried putting an M19 (spindle orient) which works sometimes but less and less often it seems.
    Jan 2012
    indiana, usa
    168
    41
    Our integrex uses this
    T018018.1B041
    (8-32 TAP)
    M518
    M200
    G40 G98 M8
    M153
    G97S400 M203
    G19
    G28 H0
    G0C120.
    Y0.Z-0.25M8
    X3.45
    X2.8
    G88 R0.05 X1.65 F12.5
    C240.
    G80
    G0Y0.
    M9
    G0X8.
    G0Z1.0
    G28U0.
    M205
    M1
    The other one uses this
    T0909.1B20
    G0G40(6-32 FORM TAP)
    M518
    G19G99
    M8
    M200
    G97M203S600
    G28H0
    G0X1.85Z-.475M8
    G88.2X.0F.0313
    G80
    G0X8.0
    M205
    M202
    M1
    Just depends on the options and parameters.
