cgmaster
Cast Iron
- Jun 9, 2008
- Ocean Springs, MS
I have been working on a MAzak Integrex with Fusion 640mt control post for Autodesk HSM. Should also work with Fusion.
Here is a link to the post in the CAM section. THis will also be very close for other Mazak lathes with live tooling and can easily be modified once it is complete.
https://www.practicalmachinist.com/vb/cad-cam/integrex-autodesk-post-questions-358282/#post3280055
The first section I have done is only for turning modes. If someone wants to take a look at the output code let me know if you see any errors. I am not used to programing EIA I mainly use Mazatrol but have some upcoming projects that I plan to use CAM software for.
