Hi Guys,
The tailstock on my old QT10 is very loose when unclamped. You can probably see the top of the tailstock move 1/4 of an inch or more while its unclamped and moving. Its bad enough that its creating a gap between the ways and possibly lettings chips in between, so I need to get this fixed.
I took the cover off today and it looks like I have an air/hydraulic booster and a hydraulic cylinder to clamp. See attached pics. Looks like theres a nut that I can tighten to adjust all this, its split on one side and has a cap screw to lock it. Im guessing this has worked loose.
So hoping you guys can confirm im on the right track with this and how much to adjust it. Would there happen to be a procedure of maybe tightening all the way and back off X number of degrees or turns or do I just tighten it up till it seems right?
How do get the machine in an unclamped state to adjust it? I cut the air to machine but I guess solenoid must be still closed as its still clamped. Can I move tailstock manually and hit e-stop while moving maybe to leave it unclamped? Thanks.
Mark
Mark
