M32 887 Tape I/O error
Likes Likes:  0
Results 1 to 6 of 6
    Jan 2017
    31
    Default M32 887 Tape I/O error
    Hi all,
    I scoured this forum for 877 errors on M32 controls but could not really get good posts.
    I have the same problem on two different machines:
    AJV-18 Vertical Mill
    H400 Horizontal Mill
    Both M32 controls.
    We drip feed for about 40 min. and then an 887 Tape I/O ((Check parameters for incorrect settings) error appears.
    I checked all G parameters that have to do anything with getting data in and out.
    G1
    G10
    G19
    G20
    G21
    G22
    G23
    G55
    G56
    G57
    G58
    G59
    I am using the http://www.highlanddnc.com/ ShopLink FLASH 2.0, "DNC in a box" as my sending unit.
    Stop bits are set to 7 on the sending config file and 8 in the M32 control.
    I checked all other G parameters and they matched my parameter sheets.
    Are there any other parameters that I need to attend to that effect Drip Feeding?
    I just talked to Jerry from Highland DNC and he suggested to take out all comments in the part file.
    We are test running it again now.
    Thanks for any help.
    Rider7
    Jul 2010
    Rochester, NY USA
    2,288
    10
    553
    What is your baud rate?
    Length of cable?
    Flow control method?
    Bill
    Jan 2017
    31
    Quote Originally Posted by hitandmiss View Post
    Length of cable?
    Bill
    Bill,
    I tried 4800 and then 2400 since I thought it might be having trouble buffering etc. although a 887 error refers to parameter settings.
    Flow control method is completely controlled by the shoplink flash box by the config txt file:
    BAUD=2400
    MODE=7,E,2
    BUFFER=128
    WAITFORXON=1
    EXT=txt
    RECEIVE=0
    RECEIVESTART=0
    RECEIVETIMEOUT=99
    length of cable is only about a foot.
    Oliver
    Jan 2017
    31
    Update on drip feed issue:
    We switched from the shoplink flash DNC box to a PC and drip feed it with CIMCO edit software.
    Now we get an "806 Illegal Address" error around the same time (30-40min).
    If anybody has seen an 806 error and has some input, I'd be thrilled.
    I am talking to Mazak applications, but so far no solution either.
    Oliver
    Oct 2021
    Oregon
    I realize this is from a long time ago, but did you ever figure out the solution to this? I'm using a Highland DNC as well and it works great, except for the alarm at the very end of the program like you were getting. I'm assuming Mazak doesn't like the way the program is terminating. I tried M2 and M30 and neither made a difference. It completes all the machine work, but just sits there with the spindle on and won't home out.
    I'm running this on a Mplus controlled VTC200B.
    Jan 2017
    31
    Quote Originally Posted by GrizzlyMtn1 View Post
    Hi GrizzlyMtn1,
    we gave up on drip feeding as I could not find a solution.
    W're only using it to load appropriately sized programs into the control memory now.
    I'd say, in your case, take it as a win that you get your program through.
    Oliver
