M32 FLD Error
Nikolaiownz
Feb 10, 2018
Hello
I started getting this error when booting my vqc M32 op.
If I turn it on after a day off it will throw this message after the loading bar. But if I turn it off and on again it will jump right up as it always did when the disk is loaded.
Machine works fine but I still wonder why it's throwing this message on the first boot up.
The 6v battery is 6.8v and was recently replaced. I don't know where the other battery's are.
Can it be a faulty disk or drive? The drive reads on bootup with the green light and the system loads after the reboot no problem.
Sendt fra min EML-L29 med Tapatalk
Will usually only boot from disc if battery is going flat. There is a battery in the module beside the FDD as well as the big 6v battery and another on one of the boards(can't remember which one offhand)
Mazak service told me it was normal to boot from the disc if the control is turned of more than 24 hours.
I found the battery under the disc drive and it's a 3.6v battery that had 3.9v so it seemed ok. The big 6v battery has 6.9v.
Don't know where the other battery's is
The mazak dude apparently was wrong. I changed out the 6v battery and it dosent load the disc after it's been of for a day. Seems like it needed a new battery. Now I hope I dident wear out my system disc by loading it to much.
