Isak Andersson
- Nov 3, 2021
Hi again. I got an annoying error that I can't figure out how to get rid of.
Error 264: Thermal Trip (Single Block)
Cause: A motor on/off thermal relay switch that does not have direct effects on the machining (such as chip conveyor motor) has tripped.
Action: Check the regarding unit (e.g chip conveyor for clogging with chips) and reset the thermal relay. Adress X5, X7
1. How can I know which relay has tripped?
2. How do I reset the relay?
3. Can I prevent the machine from going into single block mode when this happens? I don't really see why that would help in any way since it has no effect on the actual machining.
Thanks!
Edit: It seems the conveyor isn't moving so I assume this is the cause of the problem. I still don't understand how I'm supposed to know which relay to reset and how to do that. Is it just like a fuse that needs to be switched or is it more complicated than that?
Thanks!
