Isak Andersson
- Nov 3, 2021
So this one really stumped me. I'm trying to manually program my finishing tool so that it does exactly what I want it to do. The problem is it's not doing anywhere near what I programmed it to do. It goes to completely different coordinates than what I programmed even tho the virtual machine is showing the right coordinates. What's going on here?
I also don't see any way to insert an S-code so how am I supposed to change the cutting speed? Also if I restart at the MANL PRG unit the spindle doesn't start at all. Do I need to manually insert an M3 and if so how do I do that?
Alternatively, if someone could tell me how to reverse the direction of machining in a Mazatrol program that would work too. Thanks!
