Isak Andersson
- Nov 3, 2021
Hi guys. Is there a parameter that will control how long the W-axis will wait before returning home during a sub-spindle transfer? I've had this issue now where the main spindle chuck doesn't have enough time to open before the W-axis returns home which causes the part to be pulled out of the jaws slightly. Best case scenario this makes the part slightly shorter. Worst case it crashes the machine.
Now I'm pretty sure this happens because of a faulty chuck. The chuck only has a jaw stroke of about 2.3 mm on the diameter but I believe it's supposed to have 8.8 mm. This is, of course, something that has to be fixed in the future but for now, a workaround solution would be to increase the dwell time after the W-axis press is complete.
What do you think? Can it be done?
