mazak 100y chuck not works
Results 1 to 6 of 6
    Sep 2017
    POLAND
    50
    Default mazak 100y chuck not works
    hi guys
    i bought an Integrex 100Y mazatrol 640mt and i have a problem with chuck
    shows ok when I press the pedal, but hydraulically it doesn't open the chuck, nor through the code m6 and m7 but shows on cnc signals ok
    with closed and open
    pressure is ok
    maybe something is turned off in ladder or parameter
    Sep 2017
    POLAND
    50
    everything works but i cant clamp and open chuck hydraulic
    m6,m7 works
    foot pedal works
    solenoid when I press it works
    but
    , does not receive a signal to the solenoid valve
    Apr 2014
    AUSTRALIA
    619
    237
    152
    sounds like it might be a relay not pulling in.
    Jul 2006
    Arizona
    4,715
    18782
    4561
    Quote Originally Posted by wojtekthx View Post
    pressure is ok
    If the foot pedal works to actuate the chuck but the M-codes do not, you need to enable a parameter that allows chucking in auto operation. Look in your electrical manual or parameter manual for the parameters specific to your machine. It's a simple fix, but I don't know what parameter number you need to change.
    Jan 2012
    NY USA
    136
    28
    Check under machine menu to see if "barfeed mode" is turned on. It will prevent manual operation of the foot switch.
  6. Likes wojtekthx, Pete Deal liked this post
    Sep 2017
    POLAND
    50
    solve SET UP Manag. Chuck Valid/Invalid was Invalid now everythings works thanks
  8. Likes Philabuster liked this post
