Mazak 515/40
Results 1 to 3 of 3
Thread: Mazak 515/40
    Jun 2018
    CANADA
    Quebec
    13
    Default Mazak 515/40
    I have a Mazak 515/40 and my coolant pump doesnt work its leaking through the seals. I took it to a hydraulic repair shop a the tech told me that its a low quality pump probably added later. So the information i am looking for is how many gallons per minute is required the pump runs at 1740 rpm. The milling also has a through spindle coolant.
    Dec 2014
    New York
    814
    294
    194
    You should have Grundfos pumps, can you take a picture? Whats original spec on your TSC is it the lowest Mazak offered at the time (something like 250 PSI)
    at minimum I would be looking at Grundfos MTH4 60/6 it is not a thru high pressure pump but it delivers.
    Jun 2018
    CANADA
    Quebec
    13
    Default Coolant Pump
    Hi Kaszub,
    Thanks for the reply
    I am not sure of the machine spec i am missing a few books. i currently have a pump
    Eaton
    26002-RZC
    F120221JR
