Jturtle
- May 5, 2017
- Rolling Meadows IL
Mazatrol M-32 control, I'm having issue with a tool change operation. Everything is fine when I got from Magazine to spindle but from spindle to magazine I'm getting dropping. Looks like the position my spindle stops at to wait for the arm is off by a few thousands. I need to change the Y-axis tool change position parameter. Any help on how to go about that would be appreciated. I have books on parameters and have done them On Haas, VCN and Mori Seiki Lathes but have yet to do anything On AJV so just looking for any tip, tricks or things to avoid and how to get started. Thank you.
EDIT
I found it to be the Home 2 tool change Parameter M5.
Think I comfortably got it. I'm doing my movements by .01 each and adjustment and checking after.
So I'm having trouble with My machine dropping the probe and only probes. I've even tried another probe from another AJV that I have and it wouldn't seat the probe fully. can't seem to figure it out. only drops probes and did it to 2 different probes. Doesn't make sense. Any thoughts?
EDIT
