I have had to hand reload Machine Parameters in our AJV25-405 M32-B control
But for some reason the R1 - R3 are missing from the set sheets (were not hand written on sheet)
Machine starts okay with no alarms as I loaded all - 0 for R1 to R2 and
12 for R3 similar on our VTC- 20B
But will come up with Alarm 55 when at home postion
Also on each axis shows high loads on meter at home postion
The Z travel not correct if I move .10mm on screen its moving .40 on dial clock
R3 is Ball Screw pitch so 12 may be incorrect but our machine has offset belt drive on Z axis
Also that maybe playing with my settings
Anyone have a similar machine to advise what there R parameters are
