Mazak Coolants being used
Results 1 to 5 of 5
    Jun 2011
    Wisconsin
    44
    Default Mazak Coolants being used
    Hello, I have a question. What IS everyone using for coolant in their machines? I have tried a few different ones and they end up gumming up and / or leaving films and oily residue on the tooling. I am looking for something that kind of stays watery like. I use an oil skimmer in the tank as well but just not happy with the coolants so far. Thank you in advance.
    Jan 2019
    North Carolina
    246
    44
    171
    Can you elaborate on "gumming up"? The oily residue you're describing is, well, the coolant. And you want it there -- it's a rust preventative.
    Coolant serves multiple purposes, one of which is to provide a rust barrier for your machine and tooling. If your coolant wasn't leaving some kind of residue once the water it's mixed into evaporates, I'd be worried.
    Now as far as gumming up goes, I'm not entirely sure what you mean. If you mean literally coagulating into some kind of gummy substance beyond an oil layer, that may be a problem.
    To answer your question, Qualichem Xtreme cut 251C is a common recommendation for mixed metals. If you only cut certain metals, you may be able to find something more specialized.
    Jun 2011
    Wisconsin
    44
    I guess when I say gumming up I mean that the residue left behind on the surfaces is thicker than I have normally experienced in the past. I know there needs to be some sort of film left behind as a preventative. I am just not happy with what I am currently using. Therefore looking for some suggestions. Thank you for the information.
    Jun 2013
    Oregon
    2,010
    737
    1225
    There are about a billion old posts on coolant on this forum. Search some of the old posts and you will get lots of input. The make of the machine does not matter.
    Sep 2010
    Oklahoma City, OK
    5,650
    1094
    2474
    Trim 690xt
    Programmed via Mazatrol
  6. Likes Gobo liked this post
