Mazak Hrozontal Cover Coolant
Likes Likes:  0
Results 1 to 1 of 1
    May 2015
    New Hampshire
    Default Mazak Horizontal Cover Coolant
    Hello,
    I know it is strongly suggested to never shut off the cover coolant but we have found the use of chip clearing fans to work excellent. They not only clear off chips extremely well, they also help cut down on the use of coolant by removing the majority of the coolant that is usually left on pallets before the use of these fans.
    Problem is we have a pallet line and the only way we can effectively use these fans is to have the program stop so we can manually use the coolant keys to shut off the cover coolant - not very practical.
    Does anyone know of a M-code or parameter that will allow a program controlled cover coolant off? (M09 does not shut it off).
    Thanks for any suggestions.
    Pete
    PFH4800
    Mazatrol 640M Control
