True.Scotsman
- Jul 16, 2013
- Aberdeenshire, Scotland
Machine: MAZAK MAZATECH FH-6800
Control: MAZATROL 640M
Does anyone know the parameters to control the automatic drill length compensation?
I’m guessing there would be 1 parameter to switch the automatic length comp on and off and another parameter to set the automatic drill point angle or percentage of the drill diameter.
A [CUT-ANG INPUT] function appears in the tool data page when you move down to the [LENGTH COMP.] field.
When you highlight [CUT-ANG INPUT] and enter 180 or 0 then press [INPUT] the machine automatically sets [LENGTH COMP.] to 0, but when the tool length is reset it reverts back to the automatic length comp value.
Holes in a part were drilled too deep due to the length comp being set to zero then the tool length being reset without remembering to set the length comp back to zero.
I would like to have length comp set at zero as default to avoid this happening again.
Any help would be much appreciated!
