Hi I need a bit of help CNC and am having difficulty setting the toolheight.
I have a tool setter for the height i am not sure a 100% how to use it so i decided to touch off on the material with all tools to be used.
I was explained by a local machinist that the z in G54 must be 0. and it will pull the length out of tool data section. i did that and the end result was the machine head wanted to go up instead of down. I changed the value to a negative and got an error illegal format 401 and also Gauge line height
In my post i had a G28 and it needed a G30 for a tool change not sure if this could be the problem?
