Mazak qt-6 1997 turret info/problem
Likes Likes:  0
Results 1 to 2 of 2
    Dec 2011
    lower michigan
    95
    Question Mazak qt-6 1997 turret info/problem
    I was helping out a friend on his qt-6 with a tplus control. There was a ecsessive internal hydraulic leak in turret lock cylinder. Removed lock cylinder and replaced all O-rings. When putting turret together. Turret is moving when locking and unlocking. My question is does anyone know the procedure to adjust/set turret home position?
    Sep 2005
    il.
    6,624
    30
    1209
    sounds like the high index coupling is off
    that's the 6 bolt circle under the center cap
    unclamp turret,
    loosen bolts
    clamp turret
    unclamp turret
    tighten bolts
