MAZAK QT10 setting the CHUCK open when machine is powered up
Skinny_T
Nov 22, 2019
Hi!
We have a MAZAK QT-10 T+ from around 96/97.
I was wondering if there is a SETTING og PARAMETER that makes the chuck stay open when the machine is powered ON?
Now it closes when we power the machine ON.
All feedback is welcome :)
I have never heard of such a parameter
if you where desperate to stop the chuck movement you could pull the coil connector before turning on
Try R54 bit 5 set to 1. Should make the chuck stay where it is. ie if clamped ti stays clamped, if unclamped it stays unclamped. These parameters are listed in the electrical diagram. I have seen them in the front, after M code list, and in the middle also.
