Mazak QT10N, Ball Screw Stuck In THrust Bearing Assembly
Likes Likes:  0
Results 1 to 3 of 3
    Jun 2012
    Davis Junction, Illinois
    301
    137
    100
    Default Mazak QT10N, Ball Screw Stuck In THrust Bearing Assembly
    Trying to get to thrust bearings. Can't get ball screw pushed out of thrust bearing assembly. I suspect there is crud in there. Any tricks? I would rather not pull the ball screw. If I have to, it looks like I could pull the ball nut and the thrust bearing housing on the screw to get it to the press.
    Jun 2012
    301
    137
    100
    I unbolted the far end support from the casting in order to get the ball screw to slide out of the thrust bearing assembly. Is the far support supposed to slide freely in the block?
    Apr 2016
    Tennessee
    167
    135
    22
    I wouldnt think so. Maybe Toolcat will jump on here, he would know for sure.
