Pete Deal
Titanium
- Apr 10, 2007
- Morgantown, WV
My problems started with a slideway alarm which occurred because it was low in oil. I filled it up and was not able to get the alarm to stay cleared. After manual pumping and restarting the machine several times. The machine is a 1988 and is in super nice condition. Still, I figured I maybe should pull the way covers back and look things over.
The Lube MMXL-II pump seemed to be sticking. So I worked on that some and found another on ebay for $60, so I bought that too. I put the ebay pump on since it seemed better. Still, even after quite a bit of pumping the system does not seem to hold pressure. By that I mean I would expect the pump to take a while to discharge the oil into the system. The plunger goes right down in a few seconds. I've traced all the lines and can't see any leaks. My experience has been that the metering units tend to clog up and not pass oil not to open up.
I think my next step will be to take the 3 main lines off at each end point (X, Z, and tailstock) and block them there with some fittings I have and see if it holds pressure with these lines dead headed. Then maybe order all new metering units since that's probably a good thing to replace either way.
Anybody got any other suggestions?
