JonP
- Sep 28, 2008
- N W Washington
WE have a early 90's vintage QT15 that has been having a intermitant turret problem, it goes to index and it un clamps and just sits there, you can bang it with a rubber mallet and it will index usually. It happens in a program as well as manually indexing. If you let it sit long enough it will blow one of two alarms, one is turret clamp malfunction and the other is something about too much time for turret to index. I'm kinda thinking its a prox. switch or something, guess I need to open up the back of the turret housing. Have the turret off now as there was more coolant coming out from behind it than onto the cutting tools, this problem is obvious the brass gadget and seals are toast. The turret rotation problem isn't so obvious, anyone know where the hyd. selenoid valve that activates the turret motor is? maybe that's sticking, I sure hope it's not the turret rotating motor. Any and all ideas and comments are welcomed, Thank you Jon P.
