Thread: Mazak Qt15 W/ T32-2 Control
11-26-2020, 03:35 PM #1
Hello All,
I was hoping some of you guys could lend a little help and advice on some issues that I'm having with a new to me quick turn 15 lathe circa 1989 equipped with a t32-2 control.
I have re initiated the control due to the back up battery going dead from it not being under power, and I cannot start the spindle in manual, I can press and hold the jog button and the spindle will start and turn, but it will not start in manual or auto, the machine gives a "250 spindle start miss-operation" alarm, the machine has had the proximity switches on the hydraulic closer removed, and I'm assuming bypassed, but i am unsure of where to look to see if the machine is looking for signal from the proximity switches or if they are indeed bypassed. the machine also will randomly throw a "15 system malfunction" alarm and will also randomly allow the axis's to move and sometimes wont, the numbers will change on the screen, but the axis's will not move, however no alarm pertaining to the axis's is present at anytime the z axis drive, however, will sometimes read "00" when it won't move, the spindle drive also always reads "r 0' during this all.
Any help would be greatly appreciated!
Andy R.
11-26-2020, 04:52 PM #2
Probably more to it than this, but have you tried starting the spindle in the closed state? If your chucking internal/external switch is reversed, it may think the chuck is open. Do your parameters appear OK? No asterisks or anything weird?
11-26-2020, 06:05 PM #3
11-27-2020, 05:35 AM #4
On the tailstock switch on the control panel there are 2 green lights
When you retract the tailstock you need to hold the switch in the retract position for a few extra seconds and it will flash then stay on solid
If that retract light is not on solid then the spindle with not start but will jog which is what you are experiencing so I’d suggest trying that as I had this exact issue when I bought mine last year
Also in the parameter go to machine parameter R49 bit 0
This is for *chuck stroke confirmation use*
0 = do not look for chuck sensor confirmation
1 = do look for chuck sensor confirmation
So try setting this to 0 if it isn’t already
Hope that helps
Marc
11-27-2020, 11:21 AM #5
Tailstock retract light is lit and parameter r49 bit 0 is 0, still no such luck, I also see the system time on the position screen keeps constantly scrolling or changing, does that indicate anything? Machine also keeps randomly alarming out for 15 system malfunction
I should also add that the machine has a switch for a parts catcher and the bottom light is lit for that, I try moving the switch either way but nothing changes there
11-27-2020, 01:33 PM #6
I dont think it matters on mine but have you homed the x & y axis before hand so the 2 green lights come on
I think it will be down to the chuck open and closed sensors
They are around £60 each so not too expensive to buy a couple and set them up
11-27-2020, 03:25 PM #7
11-27-2020, 04:40 PM #8
