Hi everybody,
My board PD21B which is power supply in my lathe Mazak QT30N break down(probably). Small cooling fan above the board suddenly stops. I suppose that it is power up from that board, so there is the problem. Machine can be turn on, but I'm not able to make any action. Even light inside lathe doesn't turn on. Additional sometimes when several times I turn on and turn off my machine cooling fan starts rotate and then everything is ok but after 30 minutes machine again goes bad. There is several errors on the screen for example 201 or 128(Emergency is not pressed so why?).
I have checked already every volatage and everything is ok. I also changed the cooling fan for new one and problem is still the same
Do You know If it's the problem with Board PD21B or maybe You meet such problem?
Regards
Regards
