Mazak QuickTurn 15n some alarms
Results 1 to 5 of 5
    Oct 2019
    POLAND
    Default Mazak QuickTurn 15n some alarms
    Hi,
    I have problem with my Mazak QuickTurn 15N (1990y T32-2)
    I had a problem with the main power supply in the building (blown fuses during machine start). After this time, errors began to appear sporadically.
    I thought it was the fault of the spindle controller (Mitsubishi Freqrol FR-SE) but it was in repair and proved to be good . There is a difference in voltage, which I will present in the pictures...
    When I turn on the machine, in the middle phase S1 result ground fault (phase loss on spindle controller)
    After disconnecting the signal cable (CAM11) from the MC617 controller board, normal S1 voltage appears on the spindle controller.
    CAM11 on spindle controller
    After conecting CAM11 on MC617 board, there's no led on. After disconnect, there's one LED on.
    Should I call Mazak's service? They'll probably ruin me ...
    PS. Sorry for my english.
    Feb 2015
    SWEDEN
    563
    100
    266
    I think you have a missing phase on incomming power.
    The voltage you see between ground and phase can be from another phase going through something.
    what voltages do you have at incomming to the machine?
    L1 - ground?
    L2 - ground?
    L3 - ground?
    L1 - L2?
    L2 - L3?
    L3 - L1?
  3. Likes Yatarra liked this post
    Oct 2019
    POLAND
    Thank you for reply. Voltage between phrases - 210v
    Between phrases and ground its 119, 108, 130 (only with the transformer on)
    Forgive me if I did something wrong but I'm not an electrician, but it looks there is everything OK with incomming power. There's probably malfunction inside the machine.
    Feb 2015
    SWEDEN
    563
    100
    266
    Do you have the same low voltage on S1 on the other side of the 100A fuse?
    Have you tried turn all fuses of and on again?
    Oct 2019
    POLAND
    Thanks again benganboll,
    Today I had an electrician who checked the power supply and said that everything is ok. I think problem is with MC617. I forgot to add that the spindle controller has an error 36 - Transfer error.
    Any ideas?
