i have problem with my Mazak SQT10M with turret ,Control T plus
in manual mode turret works Ok
but in mdi not works good for example T0101 and then T1212 not works
turret rotate several times and the display error 272 time exceeded
the encoder is in position 1 and the red LED is on
if i press in Mdi T06 and then T12 works good (not works from T1-T5) if i press T0101-T0505 and then T1212 not works
there is a procedure for Mazak T plus, or what parameters are responsible for the head, the encoder looks good
