Mazak SQT 10M T plus turret problem
Likes Likes:  0
Results 1 to 3 of 3
    Sep 2017
    POLAND
    46
    Default Mazak SQT 10M T plus turret problem
    i have problem with my Mazak SQT10M with turret ,Control T plus
    in manual mode turret works Ok
    but in mdi not works good for example T0101 and then T1212 not works
    turret rotate several times and the display error 272 time exceeded
    the encoder is in position 1 and the red LED is on
    if i press in Mdi T06 and then T12 works good (not works from T1-T5) if i press T0101-T0505 and then T1212 not works
    there is a procedure for Mazak T plus, or what parameters are responsible for the head, the encoder looks good
    Feb 2015
    SWEDEN
    569
    100
    268
    I think one of the position swithes is broken.
    Sep 2017
    POLAND
    46
    Quote Originally Posted by benganboll View Post
    where I should look
