Hello, I'm having a phantom alarm pop up on my Mazak SQT. On the gantry loader side it comes up with a 124 R Heat AB alarm. The manual says that there may either be 1. A break in the wiring of the regenerative resistance thermostat or 2. the regenerative resistance thermostat has gone off due to the acceleration or deceleration is too high. The regenerative resistance thermostat is set to go off at 110 degrees C. Nothing feels even close to that temperature on my GL. The issue is intermittent, it happens once or twice a week and the only way we have to reset it is to leave the machine powered off at the breaker for 1-8 hours and turn it back on. I can't find anything about this alarm other than my manual. Any help or advice would be greatly appreciated. I don't think it's a wiring issue, if it were I'd expect it to be constant and not intermittent, do I have a bad thermostat? How can I check this? Could it be a parameter issue? I have very minor experience with these machines, so if someone would be so kind as to break it down Barney style for me that would be great.
Thank you in advance.
