Mazak T2 - MCU alarm help needed
Likes Likes:  0
Results 1 to 17 of 17
    Jun 2017
    ROMANIA
    9
    Default Mazak T2 - MCU alarm help needed
    Hello!
    On my QT20N with T2 control, during a drilling operation with a 35 mm drill, machine went to NMI Emergency Stop.
    I think that Z driver was overloaded.
    From that moment on machine doesn't work anymore.
    After PowerOn i get same 20 NMI Emergency Stop and on the FX61 board i have MCUAL led ON. Also on control panel NC Alarm is also ON.
    On diagnose page on MCU Version I get a strange %2 :A and i dont know if this is beacause of servo drive fail or a FX61 board fail.
    May be Z axis overload related to the error shown on screen? I realy need some advices.
    Sep 2006
    Abingdon, VA
    3,320
    4360
    3018
    You may have blown the Z-axis servo drive, which is the TRA-41.
    Check the lights on the drive, it will help pinpoint what is going on.
    Feb 2015
    SWEDEN
    524
    94
    245
    Check all 3 incoming phases, you may be lost one.
    Jun 2017
    ROMANIA
    9
    All three phases are present.
    I remember that after machine stops i got some error on Power supply for the TRA drives but after reseting them, error dissapear and never come back.
    TRA 31 drives show no error on diag led.
    Sep 2006
    Abingdon, VA
    3,320
    4360
    3018
    DBL should only be lit when drive is slowing the motor down, I would think?
    Feb 2015
    SWEDEN
    524
    94
    245
    I think its strange that you dont have any more alarm than Alarm 20.
    Could it be that easy that you have the electric cabinet door open without the key in the correct position?
    Jun 2017
    ROMANIA
    9
    I verified all sensors and limit switches. all seems to be working.
    Jun 2017
    ROMANIA
    9
    Please take a look on this picture. It seems that there is a small load on x, z axes.
    Feb 2015
    SWEDEN
    524
    94
    245
    Quote Originally Posted by bdrotau View Post
    I would say "That is normal".
    So that might tell you that servo is OK.
    Jul 2006
    Arizona
    4,507
    18199
    4229
    Take a look at the circuit breaker switches located on the inside door of the electrical cabinet. If one of those switches was tripped, I think that shows up as an alarm 20 like the one shown.
  11. #11
    Sep 2006
    Abingdon, VA
    3,320
    4360
    3018
    Check your FR-SE spindle drive LED lights.
    Could have overloaded and blown the drive...
  12. #12
    Jun 2017
    ROMANIA
    9
    Nope. Circuits breakers are ok. Spindle drive is ok too. I have the ladder book for this machine. but i really do not know how to use it to check inputs.
    Anybody can give me a hint?
  13. #13
    Jul 2006
    Arizona
    4,507
    18199
    4229
    Is the emergency stop button pressed by chance?
  14. #14
    Apr 2013
    South Australia
    410
    111
    142
    Might pay to flip the breakers off then back on. Some types of breakers can look like they are on but have actually tripped
  15. #15
    Jun 2017
    ROMANIA
    9
    This is one of the first things i did. Until i post my issue on the forum i did some verifications.
    At this point i want to check the inputs. I see some values changing on the diagnose page (when i press estop and limit switches) but this is because these switches are ok. I don't know their address or how to locate other switches address
  16. #16
    Jun 2017
    ROMANIA
    9
    Hello. Today I found a broken 5Amp fuse behind power supply. I replaced but still no luck. I'm thinking that around that fuse should be something else broken. But there are not so many components. A diode which is ok and three bridge rectifier. If you have any ideas... please!!! Thanks!
    Trimis de pe al meu SM-J530F folosind Tapatalk
  17. #17
    Jun 2017
    ROMANIA
    9
    Can someone tell me if in P and N should i find some voltage??
