Mazak T2 - MCU alarm help needed
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jun 2017
    ROMANIA
    13
    Default Mazak T2 - MCU alarm help needed
    Hello!
    On my QT20N with T2 control, during a drilling operation with a 35 mm drill, machine went to NMI Emergency Stop.
    I think that Z driver was overloaded.
    From that moment on machine doesn't work anymore.
    After PowerOn i get same 20 NMI Emergency Stop and on the FX61 board i have MCUAL led ON. Also on control panel NC Alarm is also ON.
    On diagnose page on MCU Version I get a strange %2 :A and i dont know if this is beacause of servo drive fail or a FX61 board fail.
    May be Z axis overload related to the error shown on screen? I realy need some advices.
    Sep 2006
    Abingdon, VA
    3,349
    4458
    3095
    You may have blown the Z-axis servo drive, which is the TRA-41.
    Check the lights on the drive, it will help pinpoint what is going on.
    Feb 2015
    SWEDEN
    543
    98
    256
    Check all 3 incoming phases, you may be lost one.
    Jun 2017
    ROMANIA
    13
    All three phases are present.
    I remember that after machine stops i got some error on Power supply for the TRA drives but after reseting them, error dissapear and never come back.
    TRA 31 drives show no error on diag led.
    Sep 2006
    Abingdon, VA
    3,349
    4458
    3095
    DBL should only be lit when drive is slowing the motor down, I would think?
    Feb 2015
    SWEDEN
    543
    98
    256
    I think its strange that you dont have any more alarm than Alarm 20.
    Could it be that easy that you have the electric cabinet door open without the key in the correct position?
    Jun 2017
    ROMANIA
    13
    I verified all sensors and limit switches. all seems to be working.
    Jun 2017
    ROMANIA
    13
    Please take a look on this picture. It seems that there is a small load on x, z axes.
    Feb 2015
    SWEDEN
    543
    98
    256
    Quote Originally Posted by bdrotau View Post
    I would say "That is normal".
    So that might tell you that servo is OK.
    Jul 2006
    Arizona
    4,591
    18428
    4306
    Take a look at the circuit breaker switches located on the inside door of the electrical cabinet. If one of those switches was tripped, I think that shows up as an alarm 20 like the one shown.
  11. #11
    Sep 2006
    Abingdon, VA
    3,349
    4458
    3095
    Check your FR-SE spindle drive LED lights.
    Could have overloaded and blown the drive...
  12. #12
    Jun 2017
    ROMANIA
    13
    Nope. Circuits breakers are ok. Spindle drive is ok too. I have the ladder book for this machine. but i really do not know how to use it to check inputs.
    Anybody can give me a hint?
  13. #13
    Jul 2006
    Arizona
    4,591
    18428
    4306
    Is the emergency stop button pressed by chance?
  14. #14
    Apr 2013
    South Australia
    430
    112
    145
    Might pay to flip the breakers off then back on. Some types of breakers can look like they are on but have actually tripped
  15. #15
    Jun 2017
    ROMANIA
    13
    This is one of the first things i did. Until i post my issue on the forum i did some verifications.
    At this point i want to check the inputs. I see some values changing on the diagnose page (when i press estop and limit switches) but this is because these switches are ok. I don't know their address or how to locate other switches address
  16. #16
    Jun 2017
    ROMANIA
    13
    Hello. Today I found a broken 5Amp fuse behind power supply. I replaced but still no luck. I'm thinking that around that fuse should be something else broken. But there are not so many components. A diode which is ok and three bridge rectifier. If you have any ideas... please!!! Thanks!
    Trimis de pe al meu SM-J530F folosind Tapatalk
  17. #17
    Jun 2017
    ROMANIA
    13
    Can someone tell me if in P and N should i find some voltage??
  18. #18
    Jun 2017
    ROMANIA
    13
    I see on other machines that on the Diagnose page at MCU and PCB is written A3. On the attached image is my machine Diagnose page. Can be interpreted as a board that is malfunctioning? FX61... maybe???
    I found a old photo with diag page.
    In the past I had on the MCU line 520:A
    Now is %2 :A
    The other values are not changed?
    Should i worry about FX61 Board?
  19. #19
    Jun 2017
    ROMANIA
    13
    Hi again.
    I purchased a FX61 board from Ebay. The board came with another software version.
    After i changed those two CMOS IC's (YT2 520) from broken board to purchased board and rearranged jumpers configuration as in the old board my machine is running again.
    I keep thinking that maybe that breaking down of machine at the large drill operation was a coincidence. Because, now, i don't see how this operation can compromise functionality of FX61 board.
    Thanks all for support.
    Regards
  20. Likes cnctoolcat, benganboll liked this post
  21. #20
    Aug 2019
    Oklahoma
    Default New
    Please can you show me how can i put a new post on this website .i am just get registered.please.
