Hey gang,
I have an H500 that the laser tool setter was replaced. I went thru the Beam Alignment and Calibration procedure with the Renishaw 9000 programs. Then I used the MDI soft keys for Tool Length and Diameter (like the operator would) and it stores the tool offsets incorrectly by roughly .0300 (Z) and .4000 (X) Mazak says I have a wear offset stored somewhere. I cant find it if there is.
I think that when using MDI and it posts the G136 it calls a different sub program than the Renishaw program I used to calibrate the tool laser. But no one I have talked to can confirm that.
Has anyone ever seen this problem?
I'm desperate,
Itt
I'm desperate,
Itt
