Mazak vqc 15 mazatrol M32 tool measure adjustment.
Likes Likes:  0
Results 1 to 9 of 9
    Feb 2018
    DENMARK
    147
    10
    101
    Default Mazak vqc 15 mazatrol M32 tool measure adjustment.
    Anyone know how it's adjusted ? My manuals dosent show it and I replaced the lower switch and now it needs to be adjusted.
    Sendt fra min EML-L29 med Tapatalk
    Apr 2013
    South Australia
    415
    111
    143
    Its done in the R parameters. Not in the shed at the moment so not sure which one offhand. Takes a little bit of mucking around and measuring but not too difficult
    Feb 2018
    DENMARK
    147
    10
    101
    Quote Originally Posted by sudsy55 View Post
    If you fine out please let me know Mazak vqc 15 mazatrol M32 tool measure adjustment.
    Apr 2013
    South Australia
    415
    111
    143
    These are the parameters on my H400 so I don't know if yours would be the same but being M32 I would say they should be the ones.R2390is the distance between the switch signals. You will have to measure them with the control. Take the cover off the tool measure so you can see the proxys. Push the plunger in slowly with a tool until the led comes on. Zero the Z then keep moving in until you get the beep or the led comes on on the second proxy. Note the distance and put a slightly higher number in R2390. R2391 is the actual measure position (Command page machine position). R2396 is the X position that the tool is in the centre of the plunger. R2398 is the Y position for centre.
    Hope this helps.
    Feb 2018
    DENMARK
    147
    10
    101
    Where do I find these parameters ? I can't fin them
    Apr 2013
    South Australia
    415
    111
    143
    You press the management button then go to PLC I think. Will check tomorrow
    Apr 2013
    South Australia
    415
    111
    143
    Press MNT
    PressPLC
    PressPREG
    Pressthe clear key once (top rh corner} (this puts the keypad in letter mode)
    Press 6 9That should give you ( R) in the brackets at the bottom
    Punch in 2390 (this should read (R2390) down the bottom
    Press enter.
    Now you should have the parameters you need to play with
    Apr 2013
    South Australia
    415
    111
    143
    How did you go? Get it sorted?
    Feb 2018
    DENMARK
    147
    10
    101
    Hello again. I've been to busy I haven't tryed it out.
    I got a few jobs I need to finish before messing around with it. I will post when I try it out Mazak vqc 15 mazatrol M32 tool measure adjustment.
