Mazak vqc 15 servo lag excess.
Results 1 to 14 of 14
    Feb 2018
    DENMARK
    212
    12
    149
    Default Mazak vqc 15 servo lag excess.
    Hello.
    My old mazak started throwing this error when I changes tool. It doesn't do it every time.
    Anyone know what cause it ? I can restart the control and go again but it's getting annoying and I want to solve it.
    Sendt fra min EML-L29 med Tapatalk
    Feb 2018
    DENMARK
    212
    12
    149
    It seems like it overrunning the y axis when it does it
    Sep 2005
    il.
    6,709
    33
    1262
    servo lag tends to be when the machine is trying to run past the end of the screw or when its hitting an immovable object
    which in turn tends to be bad numbers have gotten into code.
    you probably need to reset machine zero numbers
    Feb 2018
    DENMARK
    212
    12
    149
    Quote Originally Posted by wippin' boy View Post
    Well it's weird it's not all the time. It's only sometimes when it goes to the home position/tool change.
    I have no collision or anything
    Apr 2018
    5,540
    2530
    Quote Originally Posted by Nikolaiownz View Post
    That's a fairly long rapid move ? On an older dc drive control you'd turn up the gain on the drive for that axis.
    In fact, you should probaly run through the tuning procedure for all your drives, that will make the machine run better. Prior to digital drives (you said old mazak ?) that should be done periodically. Electronics drift over time.
  6. Likes Nikolaiownz liked this post
    Feb 2018
    DENMARK
    212
    12
    149
    Quote Originally Posted by EmanuelGoldstein View Post
    This is a 90s M32 control. Ok I will check up to see if I can find anything in the manuals about it.
    I am fairly new to mazak so I have no idea Mazak vqc 15 servo lag excess.
    My Y axis is not long. 400 mm tops
    Apr 2018
    5,540
    2530
    This is not necessarily what your problem is, because those helpful error messages often point in the wrong direction. But ...
    Servos have to have a following error to work. When the axis is where it is supposed to be, then they don't move. When you give it a command, say, "go ten inches plus at a feedrate of 250 ipm" then there is immediately an error between where it is and where you told it to be. That's called following error and the control and drive adjust the current to the motor depending on how big that error is to speed it up or slow it down.
    The computer has a range of following error it allows. If the amount allowed was zero then it would error out all the time because nothing can move instantaneously. But if the error gets too big, then the axis can get ten feet behind where it's supposed to be, which is detrimental to accuracy.
    So the drives are adjustable. Analog ones are, anyhow, I don't imagine these are digital ? If they are, ignore everything I just said
    What appears possible is that your electronics have drifted out of range, so the motor is not being goosed enough to keep the following error within tolerance, which generates an error message and shuts down the control. This usually won't show up in a real short move, like 1" or so, but 16 inches at rapid ought to be plenty of motion to get too far behind.
    First thing I would do is get out the electronics manual and look for the procedure to tune up the drives. Do all of them so they are the same, then your circles will be rounder and your angles will be straighter. Being absolutely on the money is not as important as getting them all the same, especially X and Y.
    You should do this anyhow because electronics do drift over time. The whole machine will run noticeably better if you do.
    If you haven't done it before, it's useful to have someone who knows what they are doing do the adjusting while you watch and ask questions. Is ewsley near you ? It's worth the investment ...
    Again, if your drives are digital then I'm all wet, ignore me This is what digital is supposed to avoid.
  9. #8
    Feb 2018
    DENMARK
    212
    12
    149
    So I did digg alittle into the machine today.
    There is two encoders on the y axis. One on the motor and one of the ballspindel. The spindel is run by a belt from the motor.
    The only way the machine can get errors if its hardware related is if the belt is lose or woren out. Or one of the encoders are bad.
    Because these two encoders are the only way the control knows where the machine is.
    I will be looking for info about this belt.
    I might see if I can provoke the error. It only does it if o change tool af full rapid. Not if I run slow so it indicates it might be the belt.
  10. #9
    Apr 2013
    South Australia
    445
    120
    148
    The one on the motor is a tach generator. The one on t he end of the ballscrew is the encoder. My understanding of servo lag is when the signal to move is given but not excecuted in an given time. Maybe try and slow your rapid down in the parameters and see what happens
  11. #10
    Feb 2018
    DENMARK
    212
    12
    149
    Quote Originally Posted by sudsy55 View Post
    I already know that slowing it down in rapid helps but I want to fix it. I don't want slow rapids.
  12. #11
    Sep 2005
    il.
    6,709
    33
    1262
    if slowing the rapid helps you probly need to get the drive rebuilt
    if it is only doing it in one particular spot you have some sort of physical restriction or coordinate error
  13. #12
    Sep 2005
    il.
    6,709
    33
    1262
    just thought about fact on this mill it could be a failing counterbalance.
    but that would be less of a chance probly
  14. #13
    Feb 2018
    DENMARK
    212
    12
    149
    It only does it when going to home pos for tool change or just g28. It dosent do it all the time.
    Is there counter balance on Y axis ?
    I suspected a woren or lost belt for y axis or something.
    I haven't seen the error any other place in the machine.
  15. #14
    Feb 2018
    DENMARK
    212
    12
    149
    This is what the drivers say when the error comes
