Hello all
I have a MAZAK VTC 800 matrix2 Controller. Alarm 366 battery low atc arm sould be a easy fix. changed alot of em earlier but newer to not be able to Clear alarm With Power off/on
Replaced the Mrj2 battery With a New, measured it to be 3,67V before swap. Turned off/on machine but the battery alarm is still there.
When i open the mrj2 setup software and change the axis to ATC arm, it says low voltage 2.8v. I measured the "old" battery also to be 3,66V
The plug is correctly plugged in
I have also measured the other 2 and all batterys are good. But im quite sure im changing on the correct drive cause there is only one of them blinking AL
Anyone experienced this or have any advice, would be much appreciated
JarlEJensen
JarlEJensen
