Mazatrol Cam T-2 Tool Path or hacks to control the path
Results 1 to 9 of 9
    Jun 2014
    Canada
    28
    10
    Default Mazatrol Cam T-2 Tool Path or hacks to control the path
    I just bought a mint QT -25 and am just familiarizing myself with the programing. I'm pretty good with my T-32 and getting better with the T-plus. I use the TPC to avoid my tail stock with those systems. However I can't find TPC in the T-2. My guess is it wasn't developed yet. Is there a way to tell the tools where to start cutting or was running the tooling into the tail stock just a thing back in the 80's ? Thanks in advance for any help or tricks. Like I said this thing is in like new shape and I'd really hate to put any nicks in it.
    May 2018
    New York
    192
    145
    94
    You define the OD-max to a large diameter
    Jun 2014
    Canada
    28
    10
    Okay so I define the O.D. max in the first line of the program to say 6". The tail stock is is under that.
    1) do I have to use that 6" diameter in the CPT X line in the first bar out line?
    2) will it return the same path and not take a short cut diagonally through the tail stock?
    Thanks for the quick reply. Seems like this is a simpler answer to using the tpc in the t-32 and t-plus. unless you wind up cutting air. I'm going to go try it.
    May 2018
    New York
    192
    145
    94
    You can use whatever CPT you would like and it wont do air cutting
    IIRC Edge and internal features will not look at OD max, but they shouldn't be used with a tailstock anyway.
    May 2018
    New York
    192
    145
    94
    and watch Phil's videos, Mazatrol Lathe Training Videos--Need Your Ideas Please
    Here he is showing the tailstock trick
    https://youtu.be/BxkCWjzhZP0?t=404
    Jun 2013
    Oregon
    2,010
    737
    1222
    Use a Mazatrol manual unit to dictate where it goes before it indexes.
    Jun 2014
    Canada
    28
    10
    MNP 1 On my T-32 and T-plus or it rotates the tool into the work piece or chuck right?
    Jun 2014
    Canada
    28
    10
    Quote Originally Posted by Jmaks View Post
    Awesome videos. I've been watching them all night. Things that are confusing me are. the material settings in the the lathe cutting conditions. Are they pre set? I tried adding 4140 and it doesn't show up when I try to write a new program.not that it matters I'm just used to punching the material in and having the pre set numbers. More convenient.
  9. Likes cnctoolcat liked this post
  10. #9
    Jun 2014
    Canada
    28
    10
    Quote Originally Posted by _EMF_ View Post
    I think I figured it out. there's about 4 materials that are pre set in the machine. Then you can enter your own. They are high lighted in a different color and don't show up on your display while you're writing a new program. You punch in the number and that becomes your material.
