aerowizard
- May 17, 2021
Suddenly I can not transfer programs to/from DNC. Using ENETDNC with CMT I/O has always worked on this machine. Re-ended the ethernet cable and the tester says its good to go. Replaced the RSD232 of whatever the pin connector is called. Can someone tell me what the setting need to be in eNET as well as the parameters of the machine? This is a Quick Turn 250 model. I do not have software on PC for mazatrol so I dont think I can use a card to save/load programs. Also if you have a better way to do this, please share! I've been having to reprogram everything and it is becoming an issue.
