Mazatrol - Machining with C-axis brake rather than clamp?
Results 1 to 6 of 6
    Feb 2019
    NORWAY
    13
    Default Mazatrol - Machining with C-axis brake rather than clamp?
    As title suggest, is it possible to run with C-axis brake by adding M-codes in the operation?
    Currently running a small part with 72 threaded holes around the OD, and by milling/drilling/chamfering and threading it's 4 tools x72 holes x20parts.
    Safe to say there's too much downtime by just clamping and un-clamping C-axis between holes. Would be great if it could just run with the brake on.
    Integrex I500
    Smooth X
    Oct 2013
    Hartford, CT
    334
    214
    135
    Parameter SU153 bit 6 will automatically output an M210/310 for C axis clamp when set to 0 (factory setting). If you set it to 1 and use an M211 in your program for the brake you should get one what you want. If the holes are pretty small I wouldn't even bother with the brake, the motor is plenty strong enough to hold position.
    Feb 2019
    NORWAY
    13
    Quote Originally Posted by CNC Hacker View Post
    SU bit6 was on 0, changed to 1 and ran with M211 but it still clamps / un-clamp between each hole. Am I missing something? I've programmed using "C-point machining" if this matters.
    Oct 2013
    Hartford, CT
    334
    214
    135
    Hmm if that didn't work, you can put an M214 in an M code unit before. That prevents the C axis from ever clamping. Once you're done, M215 will put it back to normal.
  5. Likes Mokki liked this post
    Feb 2019
    NORWAY
    13
    Oh my lord, this did it! Thank you so much! Shame M211 didn't seem to work though, would make it a bit more tidy in the program.
  7. Likes CNC Hacker liked this post
  8. #6
    Oct 2013
    Hartford, CT
    334
    214
    135
    Glad to hear it. Looking at that parameter description again I may have misinterpreted. I think that is saying whether you want the C clamped for regular XY point machining, not C axis point machining.
