Mazatrol T Plus
Results 1 to 15 of 15
Thread: Mazatrol T Plus
    Aug 2013
    IL USA
    62
    15
    Default Mazatrol T Plus
    Looking at buying an old lathe, need to know if Mazatrol T Plus supports DNC as standard and how much program memory it has standard. Additionally, how well does DNC'ing a program from a modern CAM system go on an old control? Anything else to add? Looking at an old control seems pretty intense without a good guide.
    Machine is a 1996 Mazak QT-20. This thing looks great, 5k RPM, 2 inch thru bore, nice and rigid with good HP to boot.
  2. Likes Laurentian liked this post
  3. #2
    Feb 2015
    SWEDEN
    593
    105
    284
    Hi,
    First you need to know if the machine has the EIA/ISO option to be able to use a CAM system.
    If it has that option I think you can dropfeed as standard if that is what you mean by "DNC".
    Yes the control is old but a modern CAM system should be able to generate the correct codes.
    But if you learn mazatrol you dont need any CAM system at all.
    Apr 2013
    South Australia
    437
    119
    148
    Unless it has live tooling as well as Beng has already mentioned just learn the Mazatrol and you don't need DNC. On a mill different story depending on what you are making
    Sep 2006
    Abingdon, VA
    3,425
    4624
    3215
    The T and M-Plus controlled Mazaks should have EIA programming as standard...as that was one of the advertised features of the new Plus control at the time.
    I have a ‘95 T-Plus lathe, and a ‘97 M-Plus vmc, and they both have EIA programming and upload/download capability.
  6. Likes meowkat, Laurentian liked this post
  7. #5
    Aug 2013
    IL USA
    62
    15
    I'm not entirely sure learning mazatrol would be the best way to go considering some parts I get only have a 3d model and some really funky curves.
    Any idea about the Mazatrol Fusion 640T controller drip-feeding?
  8. #6
    Jul 2010
    Rochester, NY USA
    2,204
    10
    524
    Use Mazatrol for it's strength, the simple stuff then call a G code sub for the complex shapes.
    Now you have the best of both worlds.
    I am not sure what you would be making on a 2 Axis lathe that needs a CAM system!
    Bill
  9. Likes sudsy55, Gobo, Laurentian liked this post
  10. #7
    Aug 2013
    IL USA
    62
    15
    Quote Originally Posted by hitandmiss View Post
    Bill
    There's only one part on this part I'm looking at that isn't a funky curve and it's a straight section. To make things easy I would need a live tooled lathe or a mill turn. I definitely want to be able to do it though.
  11. #8
    Nov 2014
    Florida
    4,081
    1617
    1902
    Bill
    Ummm... everything? I hear all the time how easy it is to finger cam lathe stuff... but I still can't do it as fast as cam.... now add a fillet here, a chamfer there, and BOOM cam looks amazing... not to mention I can directly download a step/dwg/parasolid, etc etc.... and program directly to the drawing file, and not read a bazillion numbers...
  12. Likes Laurentian liked this post
  13. #9
    Feb 2015
    SWEDEN
    593
    105
    284
    So how do you know the outcome is correct if you dont read these numbers?
  14. #10
    Aug 2013
    IL USA
    62
    15
    Quote Originally Posted by cnctoolcat View Post
    Does that mean the T2/T3 controls don't normally have EIA/ISO as standard?
  15. #11
    Sep 2006
    Abingdon, VA
    3,425
    4624
    3215
    Exactly, the T2/T3/M3 Mazak control’s do NOT have EIA as standard.
    Some will have it as an option though, you have to check the options page, or actually try to create an EIA program at the control. If it lets you, then it has the EIA option.
    The T/M-Plus, Fusion, Nexus, and newer controls should drip feed programs without issue.
  16. Likes meowkat, Laurentian liked this post
  17. #12
    Apr 2013
    South Australia
    437
    119
    148
    Fairly sure it wa an option on the M/T32's as well
  18. Likes meowkat, cnctoolcat liked this post
  19. #13
    Sep 2006
    Abingdon, VA
    3,425
    4624
    3215
    Quote Originally Posted by sudsy55 View Post
    You're exactly right Sudsy, EIA was an option on the M/T32 control. Good catch!
    ToolCat
  20. Likes sudsy55, Laurentian liked this post
  21. #14
    Dec 2018
    100
    267
    36
    EIA was definitely not standard on the T Plus. I ran a 1996 DT20 with the T Plus control for a few months last year and it didn't have EIA.
  22. #15
    Sep 2006
    Abingdon, VA
    3,425
    4624
    3215
    Every T/M Plus machine I’ve ever been around had EIA capability (including two here in the shop.)
    The machine you ran was probably delivered with the option parameters incorrectly set — which was fairly common on Mazaks back then.
  23. Likes Laurentian liked this post
