Hey all-
I'm struggling with a drive replacement. I'm unable to reset absolute position on the turret and tail-stock after replacing a drive. The replacement OEM drive that came first gave me 21-System error & 9-Absolute position malfunction codes after installing it. I found the new drive had the slave/master dials set differently than the original unit so I corrected those and cleared the 21-system error but I am unable to set the turret and tail-stock absolute position via the procedure in the Mazak manual. (machine menu 1>maintenance 1>Turret unclamp> turret/tail INI. set) The procedure calls for the turret unclamp function first but its unresponsive, as are the rest of the options despite holding the MF1 & MF2 keys.
I'm on the 2nd shift at a manufacturing plant in WA state (PST) with both Mitsubishi and Mazak closed for the evening so any help would be appreciated. Thank you!
