JHanko
- Aug 13, 2010
- Joliet, IL
After 10 years, it looks like my QT6T finally needs a significant repair. Can't complain though. The spindle power supply has been slowly dying, faulting out after a couple hours of use. A couple hours eventually turned into 1 hour, then 30 minutes, etc. Cooling fan inside the power supply is clean and operational. Troubleshooting with the Mitsubishi maintenance manual leads to the conclusion "replace unit". I found plenty of used units on eBay , but they all are located in China. Is Mitsubishi repairing these? If not, is there an authorized shop that does? Are new replacements available? Power supply is MDS-A-CR-55. I would like to remain down less than 1 week, if possible. Thanks!
