Nexus 51c owners maintenance items to check out.
Terry Z
Cast Iron
Aug 10, 2012
Gurnee ILL. USA
We own 4 of these machines and have had them for several years. We have time now to do a deep P.M. and cleaning on them. We have found on all 4 machines the grease hose that runs on the back side of the table and flexes with every X axis move is cracked and leaking grease. It is under a sheet metal cover on the back side of the table. You might want to check your machine out. Also there is a short stroke hydraulic cylinder on top of the spindle covered with a sheet metal cover. It activities the draw bar to clamp the tools. We found two with blown seals leaking fluid. Both of these are not real difficult to fix. You might want to check these two areas out on your machine.
Another thing to add, that doesn't seem to be plastered anywhere on the machine nearly as boldly as it should be: Never unclamp the spindle and just leave it unclamped for any length of time, other than just popping the tool out, or in.
The unclamp mechanism on these machines is a tiny little hydraulic unit on top of the spindle, and it's only meant to run for the amount of time it takes to unclamp the tool during a tool change.
This is great feedback on maintenance issues for these machines. It may save someone an expensive repair on linear guides in X. I'm going to check mine.
Thanks!
Ryan
This is good to know. Thank you.
Also might want to verify that all circulation fans are function inside the side electrical cabinet. Somehow NONE were functioning in 510c
