Multiplex 610 part catcher
Likes Likes:  0
Results 1 to 4 of 4
    Aug 2014
    Chile, Santiago
    38
    Default Multiplex 610 part catcher
    Hi there,
    I bought a Multiplex 610. I got the machine with problems in the floppy diskk drive. I can not load the parameters, so I entered by hands. I had a list of them in a Manual, but I Am not sure that they are the proper ones.
    I can not get the part catcher working. If I put the parameter R60 = 10001000. This suppose to have the part catcher activated, but the head number 2 does not move with this parameter in this setting.
    If I put the parameter R60= 10000000 the head number 2 moves without problem but the part catcher does not work because is unable.
    I think that the problem is in the parameters. I need to set them properly in order to work with the machine with the part catcher and the bar feeder.
    May 2009
    The Woodlands, Tx
    563
    67
    83
    Sounds like a prox switch maybe stuck. Head 2 will not move if parts catcher is not in right spot.
    Sep 2005
    il.
    6,676
    31
    1242
    yep, what he said
    parts catcher interlock
    Aug 2014
    Chile, Santiago
    38
    Quote Originally Posted by Justin_Terry View Post
    I checked the prox. switches of the parts catcher. They are good. when catchers is in backward end I have sensor ON. Same when I put the catchers in forward end.
    In Manual mode I can move the parts catcher forward and backward without problems. In AUTO mode does not work, either I have R60=10000000 or R60=10001000.
    I programmed with a M48 and M49 in the next block. I do not have samples programs using the part catchers and bar feeder, so I Am not sure in the program is OK.
